Model N front wheel bearings
Posted: Fri Sep 03, 2010 8:58 pm
by Mark P
Hello, can anyone give me the bearing numbers for the Inner and Outer or the sizes.
I know Cotwold Vintage does them but they are very expensive!!
Posted: Sat Sep 04, 2010 4:28 pm
by Tim W
if you can measure your old ones (or the axle and hub diameter)
give "The Bearing Boys" a call, (01233 822150) they'll probably be able to help.
Tim
Bearings
Posted: Sun Sep 05, 2010 12:29 pm
by Godfrey.harmer
Failing that Tim just take one of your sets to a bearing supplier and they should be able to match them, thats if there is a current size that will do the job.
regards
Godders
Posted: Mon Sep 06, 2010 5:58 am
by BarryM
Mark P,
Your old Bearings will have the numbers stamped in to them and those numbers are still current. Inner Cup and Cone should be stamped 350 & 352. Outer Cup and Cone should be stamped 14118 & 14282. Check your Outers as there was a change made towards the end.
Hoffman, Timken, SKF, etc., all used the same numbering. Any good Bearing outlet will carry them as a Stock Line.
