Gear Ratio Fordson N
Posted: Tue Dec 28, 2010 1:39 pm
by Martijn
Hey people!
I've got a question: Can you see from the outside what kind of gearratio is fitted in a Fordson N (Standard) gearbox?
I can buy a Fordson N Industrial and I would like to know if it's a "fast" or a "slow" one...
Hope to hear from you guys!!
Greetings,
Martijn
Holland
Re: Gear Ratio Fordson N
Posted: Tue Dec 28, 2010 2:32 pm
by Dandy Dave
I know that the F's had different ratios. Just how many I am not sure. The N is similar. Dandy Dave!
Posted: Tue Jan 04, 2011 12:47 pm
by BarryM
Martijn,
Remove the Belt Pulley and you will see the Transmission Plate. Locate the Reverse Idler Shaft. It has a Peg above and a Peg below. If the Pegs are pressed in, then it is a High Speed. If the Pegs are held in by castellated nuts, then the Transmission is a Low Speed 4.3.
Posted: Tue Jan 04, 2011 6:06 pm
by Martijn
Thanks BarryM!
I will have a look for it...
This again proves that a forum like this is very helpfull!
Greetings,
Martijn
Posted: Mon Feb 21, 2011 6:27 pm
by Richards Fordson
Another way to check is to remove the spark plugs, select top gear and wind over 10 times. low ratio will move about 3 ft and high ratio 7 ft.
This is based on 28" wheels. it is not perfect but gives a quick guide if you are not able to remove covers.
Richard
