E27N Battery Size
E27N Battery Size
Can anyone tell me the correct size of battery for my 1948 E27N? It is TVO, not P6.
Grey Fergie
Ford 2000 - Pre-force
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
MF 20B - Industrial with 7 gang mower
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
Re: E27N Battery Size
The instruction book I have quotes 12v 57amp/hour.
Bob
Bob
Thanks Bob, I was guessing around that size. At the moment I'm using a big truck battery, but want to build a battery holder that I'll mount on the nearside just behind the starter motor. Now I can get the right size and make a neater job.
Grey Fergie
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
I recently replaced my battery with one of a greater capacity than 57ah. Cant remember exact size.
However new battery is 12" x 7" x 8" high, and fits on the standard battery shelf in front of the steering column.
Bob
Bob
Thanks Fizza, I've decided to change the location from in front of the steering column as it hides the 'Ford motor company' pressing on the end of the fuel tank, as I'm going to build the battery holder to fit whatever battery I end up with, so as long as its powerful enough to crank the engine into life any battery will do.
Grey Fergie
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
1958 Dexta
Roadless 75
MF35 Industrial
MF135 Industrial
MF135 multipower
MF 165
MF 240
MF 360
MF 20E - Industrial
MF 20B - Industrial
SAME Solar 60
