Have just finished changing PTO box to final drive seals, and the shaft output seal.
I had a real fiddle replacing the shaft.
My handbook specifically says that the shaft length is such that it will enter the splines at the front end before the rear bearing enters its housing, however that was not the case here.
I did finally get it in, but could my shaft be too short??http://www.fordsontractorpages.nl/phpbb ... =1&p=41224#
Bob
