I'm ready to replace the sump on my E27n after a bearing adjustment and ring replacement.
Is there meant to be a gasket between the rear vertical face of the sump and the bell housing, or just the two long sides?
Sump Gasket
Re: Sump Gasket
You"ll certainly need a gasket there. Trust cut one in gasket paper and a little liquid gasket on both sides to make a sure seal.
Also check the rope seal in front before remounting.
Rgds
Rgds
fizza
Re: Sump Gasket
Thanks Emiel, I thought it needed one . The parts list shows the two long side gaskets but not the vertical one.
But you are right and I will do as you suggest.
Bob
Bob
