Hi-on the battery firewall a previous owner has fixed a plate with SABTVRO 348A184717
the engine number as far as I can make out is ELADOW-6050-G
J3167
the gearbox appears to be BADKN 7007F TI
and the rear axle 47123 but very hard to read so may be wrong
Any advice/info on Tractor's age and model, also if it's likely to have the 'top' filter in the rear axle/differential much appreciated, regards, Andy
Age & Model info reqd
SkidRoe
- Location: Tetenhall Wood, UK (was Thorndale, Ontario, Canada)
Re: Age & Model info reqd
Those numbers sound like ones from a later 1000-series tractor, or maybe a late Super Major.
Can you post a picture of your tractor?
Thanks - SR
Thanks - SR
