Correct Position of Side and Rear Lights?
I have freshly painted side and rear lights ready to fit. I have repro wings on my major so no mounting holes. Can someone please send the measurements, correct position etc...
Also where do you run the loom for rear and side lights?
Regards Tom
Regards Tom
Hello Tom,
I don't know the exact measurements but maybe this will help.
The side lights were all ready in place but I renewed them.
For the rear lights I used holes that were all ready there and made sure the light came straight vertical.
I could measure it for you but it’s not easy on those round fenders.
http://people.zeelandnet.nl/hmdetroije/
Go to REPARATIES, than on the bottom of the page NEXT PAGE. The last item is about the rear lights.
Just wondering? I do not think that my power major even had holes in the fenders for lights. Just the rear light behind the seat. Were the lights "Deleted" or "not installed" on tractors imported to the US right from the prodution line? Dandy Dave!
Hello Tiger,
Made two small boxes to connect the wires down the rear fenders, so it will be protect from dirt. The wire for the side lights go up through one support on the fender and the rear light wire through the other one.
Under the tape are two connectors so the wire can be split when the rear lights must be removed. I do this with every light.
