Battery
Hi Originaly I believe it had two 6v batterys connected in series to give 12v  that filled the tray then there was a frame that fitted over the top with long bolts to clamp it to the battery tray.
I guess you have a modern 12v single Battery and will need to make up something of a similar idea to fit your application.
Or if functoinallity is more important than looks use a rubber bungie cord or something.
