Crank Pulley nut
				Fixersteve
Re: Crank Pulley nut
Thanks Pavel, There didnt seem to be excessive black smoke more white if im honest. the knock seemed to be coming from the top of the cylinder on cylinder 1 when i listened through a stethescope rather than the bottom end. I have a feeling that the injector was leaking aswell. will be interseting to see what happens when she is back together.
				nathanwhittaker
Hi does anyone know what size the crank shaft nut is
