Fuel Tanks
anthonygos
Fuel Tanks
Post by anthonygos »
Apart from the fact that the clocks are fitted to the tank on the power major, are the tanks the same on the major diesel and power, will a tank off a power fit the diesel. (bolts holes)
Don't just leave it in the shed, Fordson's are made to work, so take it out and work it....!
anthonygos
Re: Fuel Tanks
There is no need to answer it's been done....http://www.fordsontractorpages.nl/phpbb ... f=2&t=6113
Tworods
Re: Fuel Tanks
Post by Tworods »
Don't think it will fit as column hole is not on center like the major. Just going by pictures as I haven't physically seen the power tank. Still waiting for confirmation.
super6954
Re: Fuel Tanks
Post by super6954 »
Tworods wrote:Don't think it will fit as column hole is not on center like the major. Just going by pictures as I haven't physically seen the power tank. Still waiting for confirmation.
The only reason the hole is not centered and is bigger is because you need extra space for the electrical wires, hand throttle rod and tach cable to run up inside that tube, and to also allow for the triangle shaped gauge mounting bracket on the steering wheel shaft housing, to fit through the tank. The tank and steering wheel/ hood are still centered to the rest of the tractor. Nothing changes between any of the majors for off center positions of the steering box or anything else Just that tank hole.
It's just the way it needs to be for it all to fit and work properly :wink: . like i said before a power or super tank just looks awful on an ordinary, due to lack of gauge housing round the under side of the steering wheel. And being able to see the flat spot and bigger hole down the steering column :cry: .
Tworods
Re: Fuel Tanks
Post by Tworods »
Ok thanks for clearing that up. :beer:
