good evening,
I am going to need a replacement gauge for the super,should i go for new or find a good old one? are they interchangerble Super/power/diesel major.
Any advice would be great.
Hour/rev gauges
Re: Hour/rev gauges
The Diesel Major won't fit.
Re: Hour/rev gauges
The Power Major and the Super Major had the same gauges, except for the tachometer. If your Major has a Minimec injector pump, the tach is driven off of the governor and turns counter-clockwise. The Power Major and the vacuum-governed Super Majors turned clockwise. The FMD had totally different gauges.
Re: Hour/rev gauges
Thanks for the info
