Fuel injector pipes
Fuel injector pipes
During bleeding the end fell off the pipe. Closest auto parts store did not have correct size ferrule.
Can these be repaired, and if so what should I be looking for?
This is for the injector pump to injector on the rear most cylinder, what is # 3 if I was to order a new pipe, correct?
Also the seals for the injectors- wire ring side to inside or outside of head? I put it towards the outside but wonder if this caused the pipes nipple end to get compromised on tightening.
Re: Fuel injector pipes
The injector rubbers are smooth on the outside.
No 3 is this one.
Fitting a new end to an injector pipe is a job for a diesel specialist. They should be able to make a complete pipe if necessary, but check price against other replacements before committing yourself.
Billy/ Sandy,
Thanks for taking the time to post the picture. Not sure how I missed it but it would have saved me from ordering the wrong pipe! At least I have a spare #3 pipe now.
