crank handle measurements
MAXPOWER
Post by MAXPOWER »
Hello--- since my search for a crank handle has not bore any fruit does anyone have one they can measure for me so i can have one made?
thanks in advance!
Miles
Post by Miles »
Hope this helps...
Can anyone confirm this is original fordson issue?
Yes.
Kjetil
Post by Kjetil »
Something is missing.
You need a peace of steel going through the hole in the front.
Mine is different, maybe not original.
I will se if I rember to take a picture.
Kjetil
The shaft is usually part of the tractor not the handle on Majors.
MAXPOWER
Post by MAXPOWER »
Miles thanks can you please verify the square opening? i thought it was 3/4 inch looks bigger in your pictures?
