Newbie with my first project
Tiger, Be very careful! Splitting on a trolley jack is the most dangerous way to do it especially with a live clutch. You will need to do a lot of riggling to get her back together and it is easy to overturn the jack and drop the engine.
I take it by lugs you mean the lock tabs. You can use Loctite instead.
Tiger
Post by Tiger »
Thanks for the words of caution Brian i was Very careful and used plenty of axle so it wouldn't fall far, it was the locating stud out of the flywheel i needed but i managed to get the old one out.
Clutch plates and bearing turned up at 15.30 and just finished putting her together now. Lining up the clutches was a pig
Gave the engine a coat of paint while i waited for the parts to turn up hopefully finish putting her back together tomorrow and start her up. Fingers crossed
Another unfinished project
Ian
Post by Ian »
looks like u've done a great job there Tiger. What you going to do with the other engine ? Rebuild it ? I'd almost like to get my hands on a knackered engine and give it a go rebuilding it. Trouble is we use our tractor quite a bit right now so I can't really do that.
Mark
Post by Mark »
Tiger wrote:Image
Does anybody know what the pipe is coming out of the rocker cover, it goes to the air filter and my new engine does not have this
Tiger,
That's your breather tube, or some people call it a "blow by" tube, anyway you call it this lets your engine breathe, you will need to put that back on.
See ya
Mark
Tiger
Post by Tiger »
Hi Ian thanks for the comments, i will probably keep the old engine and rebuild it some time.
Thanks Mark i will re tap the valve and re plumb it, Just one question how did this engine manage without the breather. There is a 2" elbow pipe coming out from behind the pump that is unaccounted for at the moment. (probably answered my own question)
Chris
Tiger
Post by Tiger »
Ian P.s there is a knackered engine on ebay at the min £53 at the min
http://cgi.ebay.co.uk/fordson-super-maj ... 500wt_1182
EddieJ
Post by EddieJ »
Tiger wrote:Ian P.s there is a knackered engine on ebay at the min £53 at the min
Thats a 3 pot dexta unit, looks a bargain if all the accessories funtion too, a starter motor, pto shaft and hydraulic pump. A funtioning hyd pump is worth £50 on its own.
Tiger
Post by Tiger »
Tried bleeding her but the pumps seized and not getting diesel to the injectors so put the one of my old engine and she fired up on the third turn and purrs like a kitten. I'am over the moon
The 2 inch elbow coming out from behind the pump i put a hose on it and
used it as a breather instead of cutting into the rocker cover. It seems to work can anybody think of any probs
Just a few leaks to tend to thermostat, filters and maybe a bit more paint. I have really enjoyed doing this, it's great to work on something where you can see everything and actually get to it. Thanks guys for all your help couldn't of done it without you. Will post some more pics when she's all back together.
P.S Should the decompression lever be up or down, it does not seem to make any difference.
Cheers Chris
Tiger
Post by Tiger »
Hi I have noticed she is weeping a bit from the pto Shaft. Is this a big job . I have done a quick search on hear but not much luck. Thanks
Tiger,
You will have to drain the rear end.
Then unscrew the four bolts and it will come out. Replace the seal between the flange and the rear end and replace the seal around the shaft. Don't know if that's still available.
Ian
Post by Ian »
Tiger wrote:Hi I have noticed she is weeping a bit from the pto Shaft. Is this a big job . I have done a quick search on hear but not much luck. Thanks
I did this job a while ago. Park it at a steep angle then you wont need to drain any fluid. Undo the 4 bolts. If you can't pull it out, give it a hit with a hammer on the top to twist it, then you can knock it out from the bottom. I used some wood so I wasn't beating the metal directly. Should come out easy then. Pull the entire shaft out.
I remember we gave the gear on the shaft a few knocks with a lump hammer to knock it back. It does move, just need to hit it hard. There there are 1 or 2 circlips. These are a bit a pain in the ass to get off. I think we used 2 screw drivers to drive them off, not ideal but worked fine. The seal itself was a c***t to get out. I think we mostly beat and assaulted it until it broke apart. Putting the new one in was easy, just knock it in. Then do the reverse to get it back together. Unless you have a special tool to get the circlips on and off, you should be able to manage it to with a few screw drivers with the help from a friend.
Then push the shaft back in the tractor. You'll find it'll hit something. You'll probably panic for a bit realising you can't get it back in. But what you want to do is put a bit of weight on the end of the PTO shaft to lift the other end up inside of the tractor. It'll slot in then. Bolts back together and ure done ;p
One last thing, there is supposed to be a gasket on the back, but on our tractor there was none. It didn't bother making one up because I didn't realise there was supposed to be one. But it doesn't leak anyway.
Tiger
Post by Tiger »
Thanks Guys
:lol: Sounds like my kind of language My list of jobs is getting bigger
Mark
Post by Mark »
Tiger wrote:Thanks for the words of caution Brian i was Very careful and used plenty of axle so it wouldn't fall far
Tiger, what do you mean by this statement?
See ya
Mark
Tiger
Post by Tiger »
I used large axle stands and pieces of wood about half an inch below the engine so if it slipped it would only fall half an inch. Not the best plan in the world but all i had
Tiger
Post by Tiger »
Been let down by Agriline there very busy :( just waiting for filters thermostat and gasket then she's back to work
Ian
Post by Ian »
im still waiting for parts from agriline
been waiting all week :o
Tiger
Post by Tiger »
Please don't shout at me for the lights, but i need them and can't afford original. :D Parts finally turned up at 16.00 today so she should be all finished tomorrow and loader back on.
Tiger
Post by Tiger »
Thanks for all your help, she's all up and running and loader back on. Here's a pic before i scratched all the paint :evil: putting the loader back on all on my own
Ian
Post by Ian »
Looks like you've done a great job there. Nice tinwork on the tractor too. Ours really needs a new front, as the front mostly got destroyed when it hit a fence post :o also having no brakes didn't help.
Tiger
Post by Tiger »
Ian wrote:Looks like you've done a great job there. Nice tinwork on the tractor too. Ours really needs a new front, as the front mostly got destroyed when it hit a fence post :o also having no brakes didn't help.
:lol: Thanks Ian. Thats why i put the bumper on i dropped a big bail of hay and it hit the front. Well she's back to work and this is the first photo of her running without smoke bellowing out of the exhaust :lol:
A well done job Tiger.
Now you have to change: another unfinsihed job in :another finished job
Post by Dandy Dave »
A working Fordson is a Happy Fordson :D And the Farmer, He is a happy Chap also when his Fordson works well. :wink:
As we say back here, Swweeeettt Ride Man. 8) Dandy Dave!
