Hi Brian, stupid meBrian wrote:That is why I gave you the codes "fordsontractorpages" and "dotty" Dave, you use those rather than your log on codes. We had to do this to stop "nasties" changing all the information on there.
Pavel... thanks also for the gasket info. Now knowing it's composite and after reading in the book "The composition type of gasket should be fitted dry but sealing compound of an approved type is recommended for use with the copper/asbestos/permanite gasket." I reckon I'll skip the gasket goo. My torque wrench tops out at 80ft/lbs. Not sure if I should just give an additional nudge to the head bolts or buy one that cover 85-90ft/lbs on ebay. Pavel I also took pics of the ram seal removal, but as you may have seen, Brian has this section well covered.Pavel wrote:Dave, I used the Bareco head set some 3 years ago; it's the composite gasket, not the shim one. I used Hylomar on the head gasket [and others] -- no leaks so far.
I''ve also got my radiator away being cleaned out and new hoses ordered...the amount of crud inside the radiator hoses and water channels is incredible. Not sure how to best clean the block water channels out. Having a clean radiator and head, I'm really concerned about crud in the block, how do I clean the block
Also need to get temp and oil pressure guages happening. The originals are still on it, but the temp sensor has been cut and the oil is showing nothing.
Here's how it looks right now.
Thanks as always for the on-going help. Best regards to all from the top of Australia, Dave.
