New Performance Lights
Matt 1944 N
Post by Matt 1944 N »
I have been looking at the lights fitted on NPSM tractors and was wondering whether the early thousand series type lights were ever fitted or if they were an aftermarket fitment and all of the majors used the same type.
Thanks Matt
The '000nd series lights were sealed beam units and smaller in size. They were never fitted to Supers. The Super lights were different to the Major. Super lights were slimmer to fit behind the grills and in front of the radiator.
Matt 1944 N
Thanks for that, sorry I worded the first post badly, I meant to say rear lights
Matt
Hello Matt,
As far as I know all type majors had the same rear lights, and the ones on the 000 series are completely different.
I would concur with Henk on that. But I have seen New Performance tractors with the later lights fitted. I suspect these are retro-fitted
The 1964/65 parts book shows only the earlier ones.
Matt 1944 N
Thanks for this, this is as I was thinking but then saw some tractors with the later type fitted
