Roadless 6/4
David in Wales
Roadless 6/4
Post by David in Wales »
Roadless Traction built these Ploughmaster 6/4 tractors in 1963-65. Based on the Super Major fitted with 90HP 6 cyl diesel Ford truck engine and uprated clutch. The front axle is modified GMC 6x6 US army truck front axle. The axle was mounted to give the same shorter wheelbase of the 4 cyl Ploughmaster to give tighter turning circle and weight of engine gave more traction to the front axle.
David
There was not too many of those made David and the earlier ones were in green and yellow if I remember correctly
Pascal
Post by Pascal »
Hi guys,
I saw one of these (in blue/white) with a guy in The Netherlands. It was like new. Great tractor! Very impressive.
Best regards,
Pascal
Grani
Post by Grani »
Yes, an original is allways an original. :lol: Wery nice.
Mine is a "homemodified piratcopy" with 108 Hp and longer wheelbase.
Wow!!!!!!!!!!!!!
Going to look for my sock. Forgot were I left it. :D
