Hi all, can anyone tell me is it possible to swap the super major column and case into a diesel major box?? As I have a very good steering box on my super major but it is the earlier shorter item from a diesel major but I also have a very tired super major box and was wondering if it was a straight forward or a nightmare.
Regards Len
Major steering box/column??????
- Contact:
Len,
As far as I know the steering axle and column of the super and power fits on the box of a new major, and the other way around.
Just the length of the column would be different because of the gauges under the steering wheel.
If not, I think some one will over write me.
they are mostly identical units other than the power/Super units are about an inch longer to make room for the dash, also the longer unit has boses on it for the dash mount and throtle shaft that may not fit through the hole in the gas tank, not sure on this but if desparate and able to use a hack saw it will most likley work. also discovered tonight that the steering arm may be diferent but the newer unit will moste likley work on both tractors.
Pat
Pat
