Clutch spring
Ian
Clutch spring
Post by Ian »
This may sound like a stupid question ..
but where does the clutch spring attach to exactly ?
Pretty much everything rusted away around the clutch area, foot plate, footplate bracket totally rusted away. Spring long gone .. was just used without any clutch spring.
I got a new foot plate and bracket for it and spring. Just not sure how the spring is attached, perhaps I am missing something.
Could anyone photo it or something ? :)
Foxen
Post by Foxen »
The clutch pedal spring was attached to a small bracket that was welded to the underside of the foot rest, this is for a super major tho so I can't really guarantee it to be the same on your power major...
Ian
Post by Ian »
Can anyone take me a photo of this ?
It would be really helpful, thanks.
This is a pic of what the brake side looked like
the clutch side was worse if you can imagine that. Everything had basically gone except the pedal
Ian,
Take a look at this album. There are a fiew pictures that might help.
http://www.mijnalbum.nl/Album=34JYINTZ
Ian
Post by Ian »
2 clutch springs ? :o
Mine looks quite different to this setup. The foot pedal looks different. I have a bar that goes up veritcally, not horizontally like in this pic (where the spring is attached). Cant find the camera just right now. It's a power major, so live drive, if that makes any difference.
Ian,
I have the wrong spring so I use two to have the same power.
Power or new major makes no difference, but live drive could be a different setup.
