Super Major ID and Value
Posted: Mon Apr 26, 2010 9:16 pm
Hi All
Some of you may know I am not a true Major owner but have an old 1955 Weatherill based on a Major Skid. Today I went to have a look at my late God Father's Super Major. I ahve the opportunity to buy it from his estate. I obviously would like to be fair but equally I do not want to let sentiment take a complete hold. (I have enough very good memories of him not to worry about a tractor).
Perhaps some of you may be able to give me an idea of value.
I would describe it in mostly good off farm condition. I am unsure of the age but found the following:
N/S rear block OJ12
N/S behind brake 8J9
Near G/box filler 3J17
Rear axle trumpet 3J9
On machined surface ahead and above fuel pump ( scribed)
S785525 (tho' not 1005 sure)
Could not find a plate on fire wall.
I am not to sure about all the Super developments but it has the following:
Draught control with a knob that has a linkage to the lift lever and a further screw in knob below. Service selector knob.
Disc brakes that appear to work quite well.
Separate spool valve for an old (possibly Horndraulic) loader. Piped so that you select external and place the lift lever up and then control the loader with it's own valve.
Diff lock.
The tacho is working and show 1280 hours. Of course this may not be anywhere neaer true. Head lights and grill intact as a guard has been fitted for most of its life.
Engine (mech gov) started first turn with quite a lot of blue smoke which soon cleared. The exhaust sounds a little chuffy particularly as the revs are shut down. The oil looked very clean.
Steering in fair order except for loose steering wheel and possible worn splines.
Clutch (both stages) appear to work OK and main did not slip when brkes applied and 5th selected.
The tyres have little wear, I think they were fitted in the 1980s and now show age cracking around the cleats but not side walls.
The front wheels are odd, one is cast 3 spoke the other pressed steel. The rears have one set of weights fitted.
The tractor was hand painted at some time wich has probably helped preserve the tin work although the Nose cone has some slight scabbing and evidence of filler around the seams.
The mud guards are poor with much rust and holes in the braces and one has been strapped to the roll bar.
The liknkage is complete but worn and the O/S cross shaft bushing is extensively worn with the upper lift arm hanging some 2mm below where it should be compared to the N/S.
There also appears to be an oil leak close to the response Knob.
There is a diesel leak some where on the O/S but on the whole no major oil leaks. (Loader rams weep).
The rear axle was filled to the mark but I did not check the gearbox.
Well sorry to be so long winded but what do you think? Even if I do not buy it the family will like to know an approximate value. The Tractor has probably had two owners from new.
N/S rear block OJ12
Diff lock.
