Starter pinion
Posted: Tue May 04, 2010 10:32 am
				I recently swapped my 2 starters from engine to engine, only to find that 1 pinion had 10 teeth, and the other had 11. They both work fine in each engine, but not in the other engine.
I presume the ring gears will be different also.
Anybody come across this before.
One of my engines is a 63 industrial engine running a 57 starter(lever operated), and the other a 66 engine running a Lucas soleniod type starter.
Kiwi Kev
Kiwi Kev
