				Headlamps in grill
				Posted: Sun May 16, 2010 12:28 pm
				by Pascal
				Hi guys,
For my 6 cylinder, I would like to mount the headlamps in the grill instead of both sides of the nose cone.
Does anybody has a picture of the mounting plate, to put the headlamps on?
Thank you in advance!
				Posted: Sun May 16, 2010 11:24 pm
				by essex pete
				Posted: Mon May 17, 2010 5:57 am
				by Pascal
				Hi Pete,
That's exactly what I mean.
  Thank you!
It's a pity, they don't sent overseas..
Is one bracket big enough to fit both headlamps?
				Posted: Mon May 17, 2010 11:15 pm
				by essex pete
				Pascal if you don't want to make them why not email the seller and explain the situation. If not then perhaps one of us in UK can buy and send them to you. It would be less complicated to deal direct.
Can these help?
http://www.vintagetractorspares.co.uk/v ... _major.pdf
				Posted: Tue May 18, 2010 9:37 pm
				by Pascal
				That's a good idea, Pete. Thanks!
Do you know if I need one or two?
Does anybody has a picture of a bracket, that is mounted on a tractor?
				Posted: Tue May 18, 2010 10:15 pm
				by sandymac
				you need two.  one for each headlamp.
sandy
				Posted: Thu May 20, 2010 7:30 am
				by Pascal
				Thank you very much, Sandy!
How do I attach the brackets to the thombstone? Just bolt them up? I don't reminder seeing that much holes in the tombstone.
				Posted: Thu May 20, 2010 4:22 pm
				by sandymac
				They *should* line up with the cowl to tombstone bolt holes.
				Posted: Thu May 20, 2010 5:40 pm
				by super6954
    I think you might need to change the lights as well if you have the original fordson or power Major ones.  super major lights that fit inside the grill are not as deep in the back to give clearance on the radiator and have diferent mounting brackets to alter the angle of the light and I am not sure if the old light will fit in the cut out in the super major style grills that you will also need.
				Posted: Thu May 20, 2010 10:35 pm
				by sandymac
				super6954 wrote:Hi
correct.
				Posted: Fri May 21, 2010 5:52 am
				by Pascal
				Hi guys,
Thank you for your reactions!
I have ordered new headlamps for inside the grill.
I will keep you updated.
