Old or young
Old or young
I have stripped my major engine and it has double "0"rings on the liners the only problem is the block is an early type with the throttle through it to the butterfly on the inlet manifold and should only have a single "0" ring ? any ideas anyone the engine is  not the factory fitted it bares the number 5299339 not listed in any fordson books
Big lad @ todds
						Your block was made for a truck engine. They were made by Ebro and imported after production ceased at Dagenham.
You have a small ring at the top and a larger ring at the bottom as per the New Performance block and all the standard parts will fit.
all my shiny new parts have arrived its like x-mas all over again   hopefully this old girl can bail some hay this year
  hopefully this old girl can bail some hay this year   . thats untill everything else decides to break down
 . thats untill everything else decides to break down   will try to put a couple of pics up so every one can see just what i have ahead of me
  will try to put a couple of pics up so every one can see just what i have ahead of me  many thanks brian for solving my mystery
Big lad @ todds
