				Raised pto
				Posted: Thu Jul 01, 2010 3:57 pm
				by Gman
				Hello to all. I power washed the raised pto on the parts Major I have and noticed the retainer seems to cover the upper right bolt slightly. I understand this bolt should not be removed from the raised pto to keep it all together.  Do I have to remove the retainer in order to remove the raised pto from the rear end housing? Thanks for any advice.
				Posted: Sat Jul 03, 2010 8:44 am
				by JC
				Gman,
On mine, its not actually covered, but it's so close that you can't get a socket on it.  A good quality (like Snap-On or Mac) open end wrench should loosen it.  A cheap one (like Harbor Freight) will spread and round off the bolt head.
				Posted: Mon Jul 05, 2010 1:16 pm
				by Gman
				Thanks JC, I took it off yesterday. A lot of short turns with the open end wrench but it is on the bench. Thanks again.
