Where to buy fuel line nuts?
Pascal
Post by Pascal »
Hi guys,
I am trying to connect the fuel lines of my 590e. They are the same as the 4 cylinder.
Does anybody knows the measurements of the fuel line nuts?
Are they 1/4? Or 1/2? UNF?
Are the airpipes between the vacuumpump and air inlet 5/16?
Does anybody knows if I can order them with the NH-dealer? Does anybody has a NH-number perhaps?
I hope you can help me, so I can try to connect the fuel lines this weekend.
Thank you in advance! 8)
Best regards,
Pascal
Matt 1944 N
Post by Matt 1944 N »
Try Agriline, maybe under acessories and Cotswold Vintage Tractors
Tractorbob3
Post by Tractorbob3 »
Old 20 Parts Company now carries a wide range of fuel lines and fittings
Regards - Bob
1961 Super Major
Pascal,
Phone John Fishwick from Old20. He knows a lot about those things and can find the right ones for you. If you want his number just mail.
Pascal
Post by Pascal »
Thank you, guys!
Can you help me with the correct measurements?
Are they 1/4 UNF?
Henk, can you please mail me the phone number? Thank you in advance!
Best regards,
Pascal
Ian
Post by Ian »
Count the turns per inch
Measure the width of the thread on the bolt
Measure the thread pitch if you can
The first 2 should be enough to work out what type of thread it is. just google some charts on threads and match the value. Assuming the thread isn't tiny, you should be able to do it with a ruler :)
