roll frame
Posted: Sun Jul 18, 2010 3:13 pm
				hi,just picked up a frame for my FPM  I can`t see a make on it, Its a lift off type, with the brackets that fix to the axle  being angled. Question is , should the frame lead forward or rearwards, as the brackets will fit either side
 I can`t see a make on it, Its a lift off type, with the brackets that fix to the axle  being angled. Question is , should the frame lead forward or rearwards, as the brackets will fit either side  thanks, Rich.
  thanks, Rich.
  thanks, Rich.
