																			 Nick
						Post
								by Nick »
			Hopefully today is fire-up day!  Im just wondering what the valve clearances should be?  And i assume you adjust it with no pressure on the valve?
- Grumpy
						Post
								by Brian »
			0.015" Inlet.
0.012" Exhaust with Rotator caps.
Use "Rule of Nine" when setting.
Valve No.1 fully open (down). Set No 8.
Valve No 2 fully open (down). Set No 7. and so on.
Numbers must always add up to Nine.
																			 Pascal
						Post
								by Pascal »
			Hi Brian,
I am getting the valves of my 590e setted too.
Does it goes on the same way, except for no. 8 will be no. 12?
No. 1 will be the first valve of cylinder no. 1, I guess?
									Best regards,
Pascal
- Grumpy
						Post
								by Brian »
			Rule of Thirteen with the 6 cylinder, Pascal.
1 and 12
2 and 11
and so on.
																			 Pascal
						Post
								by Pascal »
			Thank you, Brian!
									Best regards,
Pascal
