				Starting my major
				Posted: Fri Aug 27, 2010 5:47 pm
				by Nick
				Ok just now i wheeled it outside and cranked it over, white smoke was coming out the exhaust and it fired on 1, then on 2, then the battery died.
So its now on charge to be ready for tommorow!
My question is, why is it puffing a little bit out the inlet manifold?
				Posted: Fri Aug 27, 2010 6:00 pm
				Your valves are not seating down, valve clearance too tight?
				Posted: Fri Aug 27, 2010 6:03 pm
				by Nick
				i wondered that, but it wasnt doing it to start with which seems strange.
im not overly sure ive done the valve clearances properly
				Posted: Sat Aug 28, 2010 2:07 pm
				by Nick
				Well it started!  Had it running for about an hour or so earlier and everything seems to be fine with it!  No milky oil or leaks anywhere, and oil pressure it alot higher than before!
				Posted: Sat Aug 28, 2010 7:43 pm
				Posted: Sat Aug 28, 2010 7:53 pm
				by Nick
				I am so pleased its ok!  Just been out on it again round my father in laws fields and she purrs like a kitten, its slowly stopping smoking too.
Just got to get the topper back on it now!
				Posted: Sat Aug 28, 2010 10:18 pm
				by Bensdexta
				What was the problem? The valve clearances?
				Posted: Sun Aug 29, 2010 8:11 am
				by Nick
				Well i didnt touch them, i just cranked it over again and it started!  (ive just done my first ever engine re-build on it)
