				Hydraulic Oil Filter
				Posted: Tue Sep 07, 2010 6:17 pm
				by icom102
				Where can i find the hydraulic oil filter on a super major?
				Posted: Tue Sep 07, 2010 8:47 pm
				by super6954
				Hi There are 2 filters on A super major There is a wire gauze on the pump intake that is located under the cast plate where the drain plug for the rear axle is ( under the drawbar) it is held on by 4 bolts. Remember to drain the oil first though. I saw one removed when the guy forgot to drain it ! it was pretty darned funny.
 . The other one is a paper element encassed in tin that is inside the rear axle on the return line from the hyd top cover. you have to remove the top to get at it and again it is better to do it with the oil out.
 I think your tractor  has the wrong hydraulic top cover on it from what I remember of pictures you posted of it a while ago. If this is the case you probably wont have the paper filter under the top cover as the early major only had a single feed pipe from the pump to the top and no return. if the pipe is still there it should not be connected.
				Posted: Tue Sep 07, 2010 10:39 pm
				by icom102
				cheers i must have a look well we never done any work to the tractor apart from change the engine so i dont know how its got the wrong cover it is a super major so i have been told
				Posted: Thu Sep 09, 2010 12:52 am
				by super6954
 I went back and looked for your pictures last night. It does have the wrong top cover on  it is from an ordinary major from 1952 to around 1960 when the power major finnished  . this is when the super first came out. I belive a comment was past about her being a heinz 57 or a bitsa in the other post with pictures
 I am guessing that she had been modified before you got it and has been wrong for more than 30 years
 .  you will not need to change that filter under the hyd top as it probably is not in there and if it is it will not be doing anything as there is nothing to connect the pipe to.
. Just wash out the one underneath the drawbar maybe take the top cover off and flush all the old gunk out and refill with fresh oil
				Posted: Thu Sep 09, 2010 1:06 am
				by icom102
				Ok have you a picture of the cover that should be on it?
				Posted: Thu Sep 09, 2010 2:39 am
				by BearCreek Majors
				This is the cover and filter assembly that should have been on it. the filter is on the end of the pipe on the right closer to the bull gear and half submerged in the oil. the aux hyd valve on my lid is an option, and that particular one is I belive a US only.
				Posted: Thu Sep 09, 2010 1:49 pm
				by icom102
				i wonder why it was changed i asked my uncle and he said the guy they bough it of as far as he can remember didnt do anything to the tractor i am confused
				Posted: Sun Sep 12, 2010 3:14 pm
				by icom102
				BearCreek Majors do you have trouble with yous brakes?
				Posted: Fri Sep 17, 2010 9:56 am
				by muz
				What is that BearCreek, a super 4 ?
* Edit* sorry ...  I just saw your other post about it being broken !
				Posted: Fri Sep 17, 2010 1:35 pm
				by icom102
				the oil in the gearbox and hydraulic oil all the same i can only find one bung on the rear of the tractor what colour should the oil be mines a cream colour bit like baileys cream lol but i betit dont taist as good
				Posted: Fri Sep 17, 2010 6:25 pm
				by Gman
				icom102 wrote:the oil in the gearbox and hydraulic oil all the same i can only find one bung on the rear of the tractor what colour should the oil be mines a cream colour bit like baileys cream lol but i betit dont taist as good
Hello icom. I believe you need to change the oil. Don't know what you mean by bung but I have a '59 Power Major. There is a drain plug for the transmission and another for the rear end. Refill trans on left side by the clutch and refill rear end below seat on rear. Use same oil for both. Look at Brian's post on correct oil at top of this forum. Good luck.
				Posted: Fri Sep 17, 2010 7:51 pm
				by icom102
				Bung is another word for drain plug i guess yeah me thinks i need that ok but trying to get my head around these damm brakes first and engine oil change tomorrow
