I’m new to the forum having just got my second tractor home... He’s called “Jack” after my late dad because I know my dad would have loved him as much as me. I have a few problems to sort out with “Jack” such as the tin work, brakes, oil and fuel leaks but I don’t see many problems with these at the moment. In a previous life, “Jack” or Freddie as he was formally known was used for boat launching and I suspect I will keep coming across damage caused by the salt water he worked in. I know its bad luck to change the name of a boat, I hope this doesn’t apply to tractors.
My first priority is to get “Jack” on the road so I need an age related registration mark. Having being through this process with “Susie May” my little grey Fergie named after mum, I have a good idea what is involved so I’d like to ask the following for the registration process: -
What is the organisation that can verify the model and age for the tractor within the United Kingdom?
Where is the Chassis/Serial/VIN number located on the tractor[/img]
