How do you replace the rear pto seal?
Posted: Tue Sep 28, 2010 7:43 pm
				As stated, my pto seal is leaking i think.  When the pto is engaged is gradually weeps oil from around the shaft, it does leak slightly when its not used aswell.  Is it just as simple as undoing the bolts around it and out it comes?
Also, the outside of the half shafts where the rear wheels bolt on are leaking slightly. How do you replace these seals? Ive seen them on agrilines site.
AND i need two new rear tyres for the old girl, they are standard sized wheels, what size do i tell whoever i buy tyres off of? And what site or company is best?
