New "new major" owner
Hi there, I just rescued a Fordson out of a field where it has stood on the South Australia/Victoria border for at least the last 4 years. A few quick questions please:
A. Engine number is 1434127 so this makes it a 1957 New Major......yes?
B. Can the brakes (inboard in my terminology) be relined without removing the rear wheels?
C. Where is best place to buy/download a workshop manual?
D. The unit has no ignition key and has been hot wired with 3 wires having to be held together to start it after which they are just released and the tractor runs fine. I'm guessing that at least 2 of them should remain in contact to keep the charging circuit active. Can I get a wiring diagram or some advice on this?
Thanks in advance
Thanks in advance
Welcome Bomoh! You couldn't have come to a better place! Go to www.fordsontractorpages.nl and click on New Major. All that you seek is there or in the heads of the very knowledgeable people on this forum who are, to say the least, extremely helpful. Good luck!
									Never give up!
- Contact:
Bomoh,
Welcome to the board. Your is a New Major June 57 with mark II engine. Throttle is going behind of the engine instead of through.
A picture would be nice.
You will work al lot easier when you remove the wheels to get to the brakes. Loosen up the shoes by the gear wheel behind the long small plate on the inside of the brake housing. Than you can get the brake drum off.
If you just have to set them again you will have to do that also by that hole and the wheels can stay on.
Take a look on http://www.fordsontractorpages.nl/phpbb ... 2&start=25
Search the board for the wiring diagram.
				JohnnyBoy
Re: New "new major" owner
Hi Bomoh, Welcome to the board, you’ll get plenty of help here and the opportunity to debate things about your FMD.Bomoh wrote:B. Can the brakes (inboard in my terminology) be relined without removing the rear wheels?
Re you brakes, I’d suggest you get the jack out and get an axle stand under for safety and get the wheel off. Read the post “FMD Brakes” and you’ll see what I did to my brakes and the corrections made to my mistakes by other board members.
JB... So what if I am having a mid life crisis, It's only hurting my bank balance
1957 Fordson Major Diesel - 1951 Ferguson TED 20 - Massey Ferguson Type 794 Plough
				The Swanndri Guy
				Supermanuel
You have the wide tyres and wheel weights. May be two persons are needed to mount the tyres again.
If the distance between us should be shorter, there could be a good opportunity for my tractor driven sandblasting equipment. With 4,5 cbm/min and 9 kilo pressure a short biz. Your tractor looks very interesting in this respect.
New Performance Super Major Manuel 08D970466
