http://www.fordsontractorpages.nl/phpbb ... php?t=2323
Basically my 62 SM stopped charging, so I replaced the dynamo with the same type (22A) which cured it except the charge light only went out when the engine was about half revs, so I replaced the regulator too, which did not resolve it .. Ive tried adjusting the regulator without success ? Should I have flashed the dynamo I'm reading in that article ? what should I try next ?
 the tractor is positive earth
