Bonnet does not fit
Posted: Tue Dec 28, 2010 2:54 pm
by nathanwhittaker
Hi all are the chassis rails on a power major longer then a just a major cause my bonnet is a about 2 inch short lol bit of a wierd question for u all
Re: Bonnet does not fit
Posted: Tue Dec 28, 2010 3:26 pm
All the rails are the same through to the end of production, so are the engines. Cannot think why you should have a problem unless you have an aftermarket bonnet or cowl. Have you checked the cowl mounting bolts and the fuel tank mountings?
Posted: Tue Dec 28, 2010 3:28 pm
by nathanwhittaker
Yeah it is a after Market cowl I only bought it 2 weeks ago I think the cowl needs re drilling
Posted: Tue Dec 28, 2010 3:47 pm
Nathan,
Send me a PM with the manufacturer/supplier of the cowl I am quietly collecting data on all these problems.
Posted: Tue Dec 28, 2010 3:53 pm
by nathanwhittaker
ok will do 2moro wen i get home
cheers mate
Posted: Wed Dec 29, 2010 2:20 pm
by Dandy Dave
Did you replace the top radiator hose? Could it be that it is too long and pushing everything forward? I had a similar problem in the past and this was the cure. I can't remember what it was that I was working on though? Dandy Dave!
Posted: Wed Dec 29, 2010 9:41 pm
by nathanwhittaker
No that's not touching anything I think big hammer is needed lol
