Transmission gear housing problem
Posted: Thu Jan 06, 2011 4:55 pm
				I cleaned my transmission gear housing the other day and went to put it together today when I noticed a crack between the bearing holes on the backside of the housing. See pictures.
Is this a problem? Can I ignore it or should I try to locate a new housing? The tractor does have a loader and backhoe that I plan using on a regular basis and I want to make the trans isn't going to blow apart on me. Anybody know what caused this? There is no really signs of the bearings slipping int he bores. I'm not sure what the discoloration to the right of the crack is from. It looks like it is from overheating but it think it may just be residue from the parts cleaner.
