				is this normal
				Posted: Fri Jan 28, 2011 4:39 pm
				by super6
				http://i321.photobucket.com/albums/nn37 ... ctor075.jp
http://i321.photobucket.com/albums/nn37 ... tor076.jpg
took of rocker cover to see if my diesel return is leaking which it is oil is like water, and found this mess.
when i started engine with cover of i get no oil to top of engine, it looks like someone has filled the top of engine with flaky black paint.
how do i clean this up?
sorry about pics i tried to reduce pixels on camera but i think i went to much.
				Re: is this normal
				Posted: Fri Jan 28, 2011 6:55 pm
				by Nick
				when i start my engine with the cover off, oil comes out of the rocker arms and runs down into where the cam is.  Looks like its all blocked up.  Have you got good oil pressure?
				Re: is this normal
				Posted: Fri Jan 28, 2011 7:56 pm
				by super6
				oil pressure is not great but light goes out when revved, it does have about 3l of diesel in oil at present so i am hoping when i change oil, pressure will be better.
				Re: is this normal
				Posted: Sat Jan 29, 2011 12:16 pm
				by Dandy Dave
				I have used a high pressure washer to clean up messes like this. I would highly recomend that you pull the pan down and see how much muck is in the bottom also before washing it down. You need to do this in a warm place, or in good weather. I have used an air hose to blow excess water out of places that it lays. Yes, an oil change should bring the oil pressure back. Find the leaks and repair them. Oil the valve train well before putting it back together. It is a sign that the engine has many faithful hours on it, and oil changes may have been few. Dandy Dave.
				Re: is this normal
				Posted: Sat Jan 29, 2011 12:39 pm
				by super6
				does the sump on a major have any hidden bolts or are the all obvious,
				Re: is this normal
				Posted: Sat Jan 29, 2011 2:33 pm
				by BearCreek Majors
				None of them really hidden but you need to look closely up front; it’s not unusual to miss one. If the pan doesn’t pop right off look again.
While you’re in there you may want to take a peek at the crank bearings, amazingly they normally survive being run in what seems to be mostly a heavy grade of fuel oil.  Look at a top insert on a rod, if you see a little brass plastiguage it, but you’re probably fine, if you see a lot of brass, plastiguage it, if it’s past the brass and into the steel of the insert….you’re going to have a bad day.
Pat
				Re: is this normal
				Posted: Sun Jan 30, 2011 7:40 pm
				by River
				For the record I don't agree with this tip.An old tractorman,former horse ploughmam,used to drain sump,then part fill with diesel/TVO,run then drain,fill with new oil. Now don't shoot me down(I'm blue to),of all the makes of engines we've ever had or serviced,our blue ones are more prone to this,even as late as 6600s.
				Re: is this normal
				Posted: Tue Feb 01, 2011 11:27 pm
				by Supermanuel
				Check also that the banjo junctions for injector overflow pipe are tight. If leaking fuel solder the the banjo pieces to tube again.
				Re: is this normal
				Posted: Wed Feb 02, 2011 6:24 pm
				by super6
				cleaned and rebuilt top of engine, dropped sump to check pan filter, amazingly the sump and mesh were perfectly clean, probably as a result of diesel in the oil.
re filled oil and started good oil pressure when cold, i have yet to get warm yet so fingers crossed.
				Re: is this normal
				Posted: Fri Feb 04, 2011 11:19 pm
				by Supermanuel
				Even the fuel feed pump diaphragm can leak. The oil pressure switch is not a reliable sign of sufficient oil pressure. The light goes out at abt. 0,3 kilo pressure and there should be abt. 2,8 kilo with hot oil, except when idling.
