Hi, looking for some help, the power steering has stopped working on my County Super 4
Would it be the pump or the ram
Would anyone know where I could get a hold of a workshop manual for the ram
Any help appreciated
Keith
						power steering ram
Re: power steering ram
When rams fail they leak oil, so my guess is it is the pump/
				JC
Its probably not the pump, they are pretty tough.  You might want to check the filter in the pump reservoir, that's probably not it, but I always like to check the easy things first.  The cylinder is the same or very similar to the Major ones.  I can copy a couple of pages out of my Major shop manual,if you need me to.  When you see how many parts it has, you may want to take it to a hydraulic shop
				JC
Double acting rams will quite often just leak past the piston seals internally and never leak outside. These rams also have integral control valves, which is where the problem could be.Ian wrote:When rams fail they leak oil, so my guess is it is the pump/
That is what was wrong with my power major. The control valve in the cylinder stuck from sitting around. I pulled the cylinder apart, carefully freed the stuck parts, and got new seals from my local hydraulic shop. Put it back together and has worked beautifully since. Dandy Dave!JC wrote:Double acting rams will quite often just leak past the piston seals internally and never leak outside. These rams also have integral control valves, which is where the problem could be.Ian wrote:When rams fail they leak oil, so my guess is it is the pump/
				kcraigmile
Hi, thanks for the replies guys, JC if you could copy a couple of the pages from the manual with the details that would be really helpful
best wishes
Keith
						best wishes
Keith
				JC
I'll scan them tomorrow, and send them to you, Keith.
				JC
I was going to email the pages to you, but they looked distorted when I tried it, so I'll just post the links to them here instead.
http://i996.photobucket.com/albums/af83 ... ering1.jpg
http://i996.photobucket.com/albums/af83 ... ering2.jpg
http://i996.photobucket.com/albums/af83 ... ering3.jpg
				kcraigmile
JC, thanks a million for posting that, was really helpful
I owe you a beer
best wishes
Keith
						I owe you a beer
best wishes
Keith
				JC
No problem, Keith.  Let us know what you find.
