power steering ram
Posted: Tue Feb 22, 2011 10:27 pm
by kcraigmile
Hi, looking for some help, the power steering has stopped working on my County Super 4
Would it be the pump or the ram
Would anyone know where I could get a hold of a workshop manual for the ram
Any help appreciated
Keith
Re: power steering ram
Posted: Tue Feb 22, 2011 11:35 pm
by Ian
When rams fail they leak oil, so my guess is it is the pump/
Posted: Wed Feb 23, 2011 12:22 am
by JC
Its probably not the pump, they are pretty tough. You might want to check the filter in the pump reservoir, that's probably not it, but I always like to check the easy things first. The cylinder is the same or very similar to the Major ones. I can copy a couple of pages out of my Major shop manual,if you need me to. When you see how many parts it has, you may want to take it to a hydraulic shop
Posted: Wed Feb 23, 2011 12:31 am
by JC
Ian wrote:When rams fail they leak oil, so my guess is it is the pump/
Double acting rams will quite often just leak past the piston seals internally and never leak outside. These rams also have integral control valves, which is where the problem could be.
Posted: Wed Feb 23, 2011 2:24 pm
by Dandy Dave
JC wrote:Ian wrote:When rams fail they leak oil, so my guess is it is the pump/
That is what was wrong with my power major. The control valve in the cylinder stuck from sitting around. I pulled the cylinder apart, carefully freed the stuck parts, and got new seals from my local hydraulic shop. Put it back together and has worked beautifully since. Dandy Dave!
Posted: Wed Feb 23, 2011 11:46 pm
by kcraigmile
Hi, thanks for the replies guys, JC if you could copy a couple of the pages from the manual with the details that would be really helpful
best wishes
Keith
Posted: Thu Feb 24, 2011 7:43 am
by JC
I'll scan them tomorrow, and send them to you, Keith.
Posted: Fri Feb 25, 2011 7:57 am
by JC
Posted: Sat Feb 26, 2011 10:27 pm
by kcraigmile
JC, thanks a million for posting that, was really helpful
I owe you a beer
best wishes
Keith
Posted: Sun Feb 27, 2011 8:11 am
by JC
No problem, Keith. Let us know what you find.
