I broke it!!!
bluecraig0776
I broke it!!!
Post by bluecraig0776 »
I noticed oil leaking from rocker cover on my '57 major diesel, went to tighten the bolts a bit and the front one broke!! Wasn't the bolt that broke, oh no, it was the threaded part on the rocker shaft that broke!! Only a tiny little bit of it left. Any ideas on how to sort it or will I have to replace the whole shaft?
I will post a pic tomorrow.
Fordson Major, Man's best friend.
1957 Fordson Major Diesel - Mid-Restoration
bluecraig0776
Re: I broke it!!!
Its ok I've just thought about welding a couple of nuts onto the rocker shaft. :roll:
Re: I broke it!!!
Bleucraig,
Glad you have a solution for the problem. Never the less, could you make some pictures from the broken part and how you have done the repair.
bluecraig0776
Re: I broke it!!!
Of course I will Henk. I have lot of help from people on here, it is only right that I do my best to help others.
Here's a couple photos of offending part, Sorry for poor quality, photos taken on phone.
JC
Re: I broke it!!!
Post by JC »
Do you still have the piece that broke off? If so, I would clean it up, braze it back on, and then run a tap through it.
Re: I broke it!!!
I think welding will give to much heat and wil disvorm the bearing. Better brase it as JC says and use silverbrase.
Supermanuel
Re: I broke it!!!
Post by Supermanuel »
Take out the rocker shaft and replace the it with a used part. Even a complete rocker shaft is not not expensive from wrecker. Important that it is from correct engine. Various rocker arm lengths exist.
New Performance Super Major Manuel 08D970466
bluecraig0776
Re: I broke it!!!
I thought quite carefully about this then decided to try welding it, if it went wrong I would source another part.
I welded in place a section of threaded rod (M8x1.25) by welding just a little section at a time trying not to generate too much heat. It seemed ok so I did the same with the other bit. Now I have two pieces of threaded rod sticking up which I can slide the rocker cover over then tighten down with two nuts.
I will post pics soon.
Craig
Kim
Re: I broke it!!!
Post by Kim »
Congratulations on your repair job; it is what I would have tried first. Replacements from a wrecker are fairly easy to come by but being a cheap old yankee, I like saving money! :lol:
Never give up!
bluecraig0776
Re: I broke it!!!
Kim wrote:Congratulations on your repair job; it is what I would have tried first. Replacements from a wrecker are fairly easy to come by but being a cheap old yankee, I like saving money! :lol:
Me too! Working in a garage helps. My boss is quite nice about letting me use bits and pieces.
