Frame Reinforcement?
Hello,  I'm a new member and this is second posting with another question.  I have been browsing and found several people mentioned the oil pan on the major being important to the structural integrity.  My Super Major has a 2711e Marine diesel with a aluminum pan.  Should I reinforce the frame?  I was thinking if I put some steel from the frame down the the cross member and back up to the frame on each side. (like a upside down king post truss)  It should help a lot.  Any one out there with any experience with this?    Thanks.  This forum is awesome!    Tom
				Kiwi Kev
Re: Frame Reinforcement?
depends if you have the front axle A frame connected to the sump, as in an original tractor.
Your tractor has a replacement engine fitted, so will probably have the A frame supported another way.
Kiwi Kev
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Hi, thanks for response.  The frame was widened to fit  the new engine and a saddle made across the frame under the engine.  The front axle A frame is attached to this saddle there is two bolts on each side holding this saddle.  Is the front axle a frame the stress point?  If it is maybe I should weld a brace from the bottom of the saddle back to the bell housing bolts on each side?  Have you heard of anyone using this engine in the major?   Sorry but I can't seem to figure out how to post pics.Thanks,  Tom
http://i321.photobucket.com/albums/nn37 ... 2major.gif
this is what i have done with my ali sump, it has worked really well.
Brett
Brett
Thanks Brett,  that is very similar to what was done on mine except I only have two bolts on top where it attaches to the frame. What I was wondering about was placing a piece of steel from the bottom of that saddle diagnally back to bolt on where the bell housing attaches to the frame. From the looks of yours it is not necessary.  Have you been running it a while?  I plan on doing some heavy work with mine.  Thanks again  Tom
i would say it has done over 200 hours like that and there is no play at all, also none of the bolts on rails or engine to gearbox have ever vibrated loose/snapped.
Last week i was pulling a trailer that weighed about 9 tonnes so it does have to put up with some real work also.
Sounds good to me.  9 tonnes!!! That is a load!  I think I'll add two more bolts, make it 4 bolts like yours, and call it a day.  the heavyist work I hope to do Is  pull three bottoms, 12' disks,  and a 3 yard dump wagon with it. Otherwise baling hay, brush hogging, and using my old combine....  Thank you much for the info.  Tom
