After my gearbox rebuild I put the engine back on..and than I discovered the pressure on the clutch pedal was very low.
 I could press the pedal down with one finger (and I am not that strong
 )So we removed the engine again. I was told to wire the spring on the clutch axle twice, so we did that...quite a hard job though.
We mounted the engine again, but still very low pressure..
 I have haven't got a clue what seems to be the problem. I can't remember changing any settings of the clutch.
I hope you can help me on this one.
Here are some pictures:
clutch pedal released
clutch pedal push in maximum
The white stuff in the clutch house is some kind of grease.
Thank you in advance for your help.
 ) ... You have the throwout bearing in backward.
  ... You have the throwout bearing in backward.  ...
 Dandy Dave!
  Dandy Dave!
