Any helpful suggestions out there for a very despondent fordson owner?
I haven't done anything like this before Brian!!Brian wrote:
This is a far simpler problem and fix than you have done before.
 Dandy Dave!
  Dandy Dave!I had already seen your trolley Laurie and found it well inspiring! I'll be doing something similar as soon as it stops raining in Ireland! Probably around spring 2012.Laurie wrote:Not sure if it will help but have a look at my post yesterday 8th Oct. I had a few sleepless nights worrying about how I was going to split the tractor safely but with two bottle jacks, some axle stands and a home made trolley it worked fine. The trolley only cost about £35 for the wheels, the rest being scrap timber . The side supports just help to keep everything in place and on my tractor there were two holes in each side rail in exactly the right place for the locating bolts.
Do need to be on fairly level ground though.
Shame to scrap her without giving it a go. Good Luck
Laurie
