modifications to the front axle of my major.
ollie
Post by ollie »
When i got my major the fron axle pivot bin and bush where totally worn out as you can see here it was the actuall casting wich has worn away the only way i managed to remove the pin was by one end with a gas torc as some one previously had tried to hit it out and mushroomed the pin.
i wanted to see if i could save the original casting so i took it to a local hydraulic ram repair center as they where the only people with the machinery i knew that may have been able too repair the casting.
this is what they where able to do for me.
the casting was bored out and new bushes made to fit also a new center pin with a grease point was made to fit.
i am very happy how well this repair has worked
Kiwi Kev
Re: modifications to the front axle of my major.
Post by Kiwi Kev »
Thats the best way to do it.
Drill it out, and then bush it back to original size. Dont forget to grease it.
Kiwi kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
Pivot pin grease point
Post by Bensdexta »
ollie wrote:... also a new center pin with a grease point was made to fit.
That's a good idea! Is this a standard pin, or your own modification? Is the pin hardened steel?
I wonder if this idea would work on a Dexta? :scratchhead:
Chug-A-Lug
Post by Chug-A-Lug »
I'm wondering the same as Ben, is it a standard pin? And could I do the same to a Dexta?
Ours is in need of some attention...
oliver17
Post by oliver17 »
all i know its the same steel as hydraulic ram cylinders the pin i though to add a grease nipple to increase the lifespan a bit :)
you could certainly get it done on a dexta
Perfect job. :clap:
Kim
Post by Kim »
WELL DONE! That's the way it should have been built in the first place. Grease is CHEAP, especially compared to major repairs. I've seen a brake line modified as a remote grease fitting to a joint that was extremely difficult to get at. When they're easy to reach, they tend to get lubricated a lot more often! :clap:
Never give up!
oliver17
Post by oliver17 »
grease may be cheap but the modifications certainly where not cheap :cry:
