Replacement Lower Link Arms
whirly
Post by whirly »
All 4 lower link balls are all "wobblie" on my FPM and I'm not sure whether it is the ball or the link that has been worn out.
Is there a reasonable replacement for the lower link arms? By "reasonable" I mean one that is as close to the original as possible/
'59 Power Major
Ancient Smurf
Re: Replacement Lower Link Arms
Whirly,
You can buy them new now days, and they seem pretty good.
If you have the one with the clips at the rear (from a Super) you can buy new balls. There cheap. But it will only replace the rear ones.
Or you could try to find a pair off old one that are good, but that's something like rocking horse manure.
There's also the possibility to weld 4 replacements on them.
whirly
Post by whirly »
Thanks :D
Unfortunately, I have the pre-Super Major links.
I've been looking for new replacements but have only found new Dexta replacement lower links. Does anyone know if there is another lower link that will be almost the same?
'59 Power Major
Ancient Smurf
whirly
Post by whirly »
I think I found a reasonable replacement:
http://www.abilenemachine.com/ford-new- ... N555E.html
It's only 35" center to center but that's only an inch shorter than the ones on it now.
Hope this helps someone else :D
'59 Power Major
Ancient Smurf
That 1" shorter may bring implements in contact with the tyres! Unless the balls are dropping out of the arms, the old ones will have many years left in them.
I was revering to the one on this picture, but I can see now theve welded two replacement on them aswel.
