Hydraulics Conundrum
Posted: Sun Nov 27, 2011 10:56 pm
Hi All,
I posted a while back about oil being blown out of the exhaust elbow on my 1955 major, and various members suggested I work the old girl reasonably hard, which I have been doing, and I am happy to report back that after unblocking the rocker cover breather pipe to the inlet manifold, the oil issue is is less of an issue now - it's still there, but not as much, so thanks to all concerned, hopefully next spring/summer will see her doing a decent job of work and that'll help alot.
However, I also recently replaced a bearing and oil seal on the offside back wheel to fix an oil leak, and all seemed well after putting it all back together without any major issues, the hydraulics seeming to be fully operational, at least by way of operating the lift arms, but when I connect my (empty) 3 ton tipping trailer, it will not tip - "feels" like not enough hdraulic oli pressue, so I thought something was wrong with the hydraulics - the connecting pipe between the pump and the hydrulics cover must not be correctly seated or some such, so I took it to my mate who has a 5 ton tipping (empty) trailer, which she managed to tip quite happily, so now I'm thinking, great it's not the tractor - must be the trailer ram, hose or the fittings - 1" quick release etc - then got my mates super major to tip my trailer, which it did, so now I'm back to thinking that its my hyraulics, but am confused as to why she'll tip one trailer but not another. I guess I'm gonna have to get the top off again and check that all is as it should be inside e.g pump or connecting pipe.
Anyone have any bright ideas as to what else it could be? as this has me confuddled at the moment!
Shazbat
Shazbat
