White smoke?
Posted: Fri Dec 30, 2011 8:17 pm
The Fordson i bought originally didn't start. I found the problem in polluted diesel, the lack of a fuelfilter in the tank and a totally blocked fuelfilter. After cleaning and replacing it fired up right away, but it's emitting quite a lot of white smoke now. Is this normal or should i look for a reason for this?
To give you an idea, look at this http://youtu.be/plx3yVHDvpk
or picture here: http://www.debendevantracy.be/MyFordson/01.JPG
