oil seal for pulley?
Hi, I need an oil seal for the pulley on my `59 power major
, I`m hoping to get one of the `old style` leather ones - any ideas please? (90mm o/d ,2.5" i/d and 13mm th ) Aye a good mix of sizes I know!! Thanks, Rich
1984 5610 FWD ,1981 ford 4610 ,1962 dexta,1959 power major, 1952 major, 1956 major, 1961 super major.
- Contact:
Re: oil seal for pulley?
Is you pulley of and dismantled?
If so please let me know the bearing sizes.
Can you put a picture of the old seal on this topic?
I have to do the job also sometime
Aussie Frank
Hi Rich,
The 90mm sounds a bit odd to me. Did you measure the hole that the seal fits into with a vernier? If not you may actually have a hole which is closer to 89mm which is very close to 3.5 inches and 13mm is near enough to 1/2 inch (12.7mm). I would check that measurement again as 3.5 x 2.5 and 1/2 inch thick sounds far more likely.
Regards Frank.
Regards Frank.
Hi, -
Henk- bearings are 6406 (30/90/23 ) and 6210 (50/90/20) =bore/OD/thickness.- Frank the bearing sizes are where the 90mm comes from! cheers, rich.
the size of the seal is 90mm x 64mm x13mm
you can order at www.technirub.nl
http://s1232.photobucket.com/albums/ff3 ... C00516.jpg
http://s1232.photobucket.com/albums/ff3 ... to0149.jpg
hi, yes thats what i had measured
any UK stockists?? - how come the sizes are metric? ta, Rich.
- Contact:
Someone told me once the bearings are metric.
Thanks for the info.
Another person told me that the super pulley was smaller than the new or power pulley. Would this be correct?
And would the bearings and seals be the same size?
He this foto bucket works?????????????
Any ideas of UK stockist of an original type seal -there is slight wear on pulley where seal runs, so I would prefer the leather type. Ta , Rich
Bump!
