new oil in re
Posted: Tue Jan 31, 2012 4:18 am
by willy wagon
want to change the oil in the rear end, so to use 20-30 if i can find it. is there a filter or screen to clean at the same time? if so how does one get at it? thank-you.
Re: new oil in re
Posted: Tue Jan 31, 2012 8:04 am
Around the drain plug underneath are four bolts, remove these and the drain plug plate will come off and with it a filter gauze. Wash and replace. You will also find a couple of magnetic bolts if you look into the hole left by the gauze, towards the front where the oil comes in.
Be prepared to get oil up to your armpits! :cry:
Re: new oil in re
Posted: Wed Feb 01, 2012 1:31 am
by willy wagon
thanks for the info. once again this site is very informative.
