vicon spinner
Posted: Sun May 20, 2012 6:47 pm
by rich2a
hi guys!, does anyone know the settings for the vicon fertilizer spinner? I know the major needs to run @1200rpm
, but which gear( flat fields) and what setting on the vicon its self
. I need to apply 3cwts per acre by the way. Any ideas ?? thanks/diolch, rich.
Re: vicon spinner
Posted: Tue May 29, 2012 7:34 pm
by essex pete
You could do with a model type plus handbook or copy for the spinner settings or it will be guess work. If it is an older machine it will probably spread 10-12m at 540rpm at the PTO. If you only have a small area only open the speader a small amount and work over a known area. You can always go over it again (I am assuming it is grass) possibly at right angles the second time. Getting quite late for fert now.
