Hi.
Can anybody advise the reamer size I should use for the brake and clutch pedal bushes on a '63 super major.
I think the shaft size is 1.1/8".
Thanks,
David
Brake and clutch pedal bush reamer size
David M
- Contact:
David
It's a machine... it will fix!
- Contact:
Re: Brake and clutch pedal bush reamer size
David,
The best thing to do is use a adjustable reamer and make it larger bit by bit until the axle just fits.
David M
- Contact:
Thanks Henk.
I will try to borrow one from somewhere.
David
